Importing parameterized input file in CAE
Hi everyone,
I am trying to import a model from one of the examples of abaqus (benchmark tutorial example 3.7.1). I will receive an error saying:
WARNING: The input file contains one or more data items which have been parameterized. Parameterized input files can not yet be imported into Abaqus/CAE. This occurred while scanning input file for parameterized data. The input file will not be imported
I searched in internet and found that some people suggested to open the file in text replace the parameter by the values and import again. I really didn't understand what does this actually mean? because I replaced the parameters with values but still I had issues to import it. here is the part of inp file mentioning the *parameters:
** MATERIALS
*parameter
density=1.0e-4
C10=7.64e-3
D=0
K1=996.6e-3
K2=524.6
Kappa=0.226
*Material, name=IliacAdventitia
*density
<1.0e-4>
*anisotropic hyperelastic,holzapfel, local directions=2
<C10>, <D>, <K1>, <K2>, <Kappa>
Would you tell me what exactly i have to do now?
Thanks a lot.
** MATERIALS
*parameter
density=1.0e-4
C10=7.64e-3
D=0
K1=996.6e-3
K2=524.6
Kappa=0.226
*density
<1.0e-4>
Thanks a lot.
RE: Importing parameterized input file in CAE
*density
1.0e-4
7.64e-3, 0, 996.6e-3, 524.6, 0.226
WARNING: The following keywords/parameters are not yet supported by the input file reader
*ORIENTATION, LOCALDIRECTIONS
*PREPRINT
Do you know what's wrong?
By the way do u know how can I import the parameterized inp file via MS DOS command ? If I do it in MS DOS, does it need any parameter replacement again?
Many thanks.
Abaqus CAE usually lags behind on "new" things that are available through the input file. The local directions for anisotromic materials is one example, parametric input is another.
And you mean the command line? Indeed then you can just run the input file using "abaqus analysis job=.... "
Option 2: Get rid of parameters from the .inp as follows:
CODE --> inp
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
But it sounds strange, so it means that I cannot import adventitia_15deg.inp in the documnetation folder of abaqus? it's strange because it is part of the Abaqus documentation. would you try to see if you can import that model by changing removing the *parameter from the input file?
I created a job after i imported the file and the job aborted very soon which I guess is due to the warning and errors that I still see after importing the model. the error was number 5 by the way.
Kind Regards
Sepanta
Memory allocation issues cause error code 5 message to pop up. ABAQUS pre-processor expects a parameter (name of the variable) in between < > keys, not a number. This is the only error in the code snippet you pasted.
I am not sure what you mean but why not just run the .inp and import the .pes?
