Mobile machine LS problem
Hi guys, quick one for you (potentially)
Mobile machine, driven almost entirely by hydraulics. Very slow so I take some readings.
Main pressure is 15 bar at idle when it should be ~25bar, LS is 4 bar. The Delta P stays around 10-11 bar right up to maximum pressure of 280 bar. Delta P should be around 17bar on this machine but for some reason it has dropped. The LS adjustment on the pump has not been touched.
I am thinking either LS leakage somewhere or perhaps a damaged pump, part of the LS system, not the actual swashplate.
Can anyone offer a different insight into this problem?
RE: Mobile machine LS problem
