WPS interchange between regional offices of the same company
A company has its main workshop in one country and many regional workshops in other countries. The regional workshops are using the welding procedures that were qualified in the main workshop.
The regional workshops have their own ISO and API certifications but the control system being followed are same as the main workshop.
Question 1: Is this allowed as per API 1104, ASME Sec IX and D1.1?
Question 2: How should this be documented in the Quality Management System that it conforms to Code requirements and also acceptable to the Clients?
RE: WPS interchange between regional offices of the same company
Please stick to one forum. An answer has been given in the API forum.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Each code may have different limitations. What is accepted practice under one code may not be permitted by an other.
Best regards - Al
