Operating vs Service temperature
Can any one please tell me what do you mean by service temeprature and operating temperature of an aircraft.
RE: Operating vs Service temperature
an example might help ...
Here is how I see Your issue... Apples and oranges, to a certain extent.
Operating temperature relates strictly to the equipment, ie: nominal temperatures + excursion temperatures over time.
Example: 350F normal [xxx-PSI], 375F max-normal[xxx-PSI], with short duration excursions [2-minutes]up-to 425F maximum [yyy-PSI], for less than 100-hours total time, thru normal life (10,000-hours).
Service temperature relate to the ability of the materials within the equipment to withstand operating temperatures, at a specified load, for a specified period of time... which must equal or exceed the actual operating conditions for the quipment to meet rated performance/duration.
Example [for the example noted above]: plastic rated at 400F-continuous service @ xxx-PSI for 10,000-hours, with short duration excursions [5 minutes maximum] to 450F @ yyy-PSI (for less than 100-hours total time, thru normal life (10,000-hours).
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
