Touch voltage calculation
Hello my friends,
I am struggling to calculate touch, step and GPR according to IEEE std 80, 2000.
soil resistance: 2500 OHM*M
fault current : 10kA
current division factor : 20%
Can I calculate standard and calculation values above without using software ?
The result is quite strange to me, I am wodering now. While calculating, I do not how to figure out surface layer deration factor(Cs), irregularity factor(Ki=0.644+0.148n). What is the differnce rho and (rho)s in the Cs equation. Is Ki equation only one?
James
RE: Touch voltage calculation
Hello 7anoter4
Thank for your great information. It was very useful to solve my problem.
James
Hello friends,
After calculating the step and touch voltage, the touch is higher than step voltage. As far as I know, step voltage should be higher than touch voltage. What am I missing now?
I highly appreciated if you comment about that.
