Help - cannot copy basin file and got warning below. Any ideal to resolve it?
WARNING 10215: Could not do requested action because the project is set to read-only.
RE: Help - cannot copy basin file and got warning below. Any ideal to resolve it?
Sorry this is HEC-HMS v 3.5
It sounds like the folder that your basin file is located in may be write-protected. If that's the case, you can probably go into the the folder's properties (through windows explorer) and uncheck the read-only option.
It determined the project was corropted.
