Revit Input File Formats?
I've been tasked with supplying BIM data for inclusion into Revit. I am wondering if our files can be some sort of neutral 3D file format, or must they be 2D .DWG files? I'd much rather supply an "exterior faces only" model of our products then having to create entirely new 3-view drawings. I am using SolidWorks 2011.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
