Desactive Dimensions menu
Hello.
Is posible desactive the menu showed in the image?
Many thanks in advance.
Best regards.
RE: Desactive Dimensions menu
You can press F3 to toggle it off temporarily (press F3 again to turn it back on), but it will reappear the next time you use the command.
www.nxjournaling.com
Many thanks Cowski.
But, there is any way to disable it permanently?
Thanks in advance.
Best regards.
Why do you want to disable it permanently since this is where you enter explicit values? Or do you think that we should display an entire dialog which you would have to hit OK on, just to enter coordinate values?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hello.
I prefer to use dimensions and constraints for all.
Many thanks to both.
Best regards.
