Need Help - Vehicular - Pedestrian Guardrails
Hello All,
I have an elevated pad (5 ft max at high end) with a perimeter retaining wall where temporary buildings will be installed. Eventually these buildings will be removed and the pad will be used as a parking lot. In areas where the grade differential exceeds 30" I am definitely installing a pedestrian handrail. However, the question arises for the ultimate condition to protect vehicles from driving over. Would someone please point me to a standard that would be used as to which grade differential calls for a vehicle guardrail? This is on private property but I acknowledge it will also depend on the level of risk that the owner and or engineer would take as to the extent of guardrail to be installed?
This project is in California, I am looking into the Cal Trans highway design manual at the moment however it feels like what Caltrans might show may be a bit of overkill for this situation. Your thoughts or input is certainly appreciated.
RE: Need Help - Vehicular - Pedestrian Guardrails
