Customer defaults
Customer defaults
Customer defaults
Hi
How to fix drafting letter size in customer defaults?
RE: Customer defaults
File -> Utilities -> Customer Defaults -> Drafting -> Annotation
If you have an existing file where you want to be updated to those new defaults go into:
Preferences -> Annotation -> Load All defaults (at bottom)
There I dont see ant letter Size or hight.Just I see only colour adjustment
Thamks
In recent versions of NX you have to customize the drafting standard to change the letter size. In Drafting -> General, choose the Standard tab and press the Customize Standard button; this will bring up a similar but smaller dialog box with choices for drafting and dimension objects not found otherwise.
www.nxjournaling.com
