Median Crossovers
Median Crossovers
We are designing a crossover. Shifting traffic across a 13' median. The diagram we reference is TA-39 from MUTCD. HOwever, in our experience, we feel the the diagram is ambiguous and agressive. However, we are just wondering what others think and use.
One additional comment is note 2 in MUTCD says to use a reverse curve using the design criteria in AASHTO GDHS. Does anyone actually build a reverse curve at a design speed of 70 MPH. it seems pretty excessive.
Any comments are welcome and encouraged.
RE: Median Crossovers
The reference to a reverse curve really does not apply to you since you are traversing perpendicullary only 25' +/-. That reference is for where a large reverse curve would fit say a 500' +/- median, and not for a simple lane change type scheme.
Also check your ADT's etc. to make sure it works. Closing the lane of opposite traffic may cause headaches if the roadway can't handle it.
Provide speed reduction if necessary for safety, and appropriate barriers, etc.
