Reduced Beam Section in etabs
How can I draw a reduced beam section in a moment frame structure using ETABS?
RE: Reduced Beam Section in etabs
What do you mean by "reduced" beam section? If you like to model a cracked section, you can edit the property modifiers form the sections form.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
