MPI on galvanized pipes
Dear all
Is it possible to do MPI on weldment on a pipe that has already been galvanized? The galvanizing took place _after_ the welding. The galvanizing thickness is about 85 microns to 150 microns.
What is the maximum coating thickness (both galvanize and regular painting) that allows for MPI?
Thank you very much in advance.
RE: MPI on galvanized pipes
I would think the the welded area would be ok to MPI since the coating has to be removed & prepped for weldment.
I not a expert on these matters so it is subject to the experts.
I have had customers request MPI over other types of plating such as chrome, but here lays the question. is
it doable.
HTH
Mfgenggear
My mistake thanks for the correction.
Mfgenggear
