Composite Layup
Composite Layup
Composite Layup
Does anyone know of a good reference text, standard, or instruction on how to draft and tolerance composite structures (eg. fiberglass panels, carbon fiber & resin etc...).
RE: Composite Layup
Dimension and tol them like other parts. They can be molded and machined how you like.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
RE: Composite Layup
ImnotfromMars,
GD&T is independent of fabrication process. What you need to know is what tolerances they can achieve, and what features they can do easily.
Talk to your fabricator. I recall that my tolerances were ±1mm, and that I needed 2° draft angle on the sides. Then they fabricated my part, they asked for my SolidWorks model. They converted this to sheet metal, and they flattened it to get their material pattern.
JHG
