AS Fusing Requirements
I'm located in the U.S. & am designing a control system to AS requirements. Incoming voltage is 690 VAC, 50 Hz. Per spec. HRC fuses are required. I need a fusible disconnect switch & fuses for the power section. Can anyone recommend a suitable switch & fuse mfr.?  Fuses will also be required for the VFD & step-down transformer primary. Also while I'm at it, can anyone tell me where to find a 690/120 transformer, around 375 VA?  Mfr. & P/N's would be appreciated. Thanks very much for your help.
