how to view results for all substeps in a nonlinear analysis on ANSYS mechanical
I am doing a non-linear structural analysis on ANSYS. Solution is found after 10 substeps. I have only one load step. The problem is that I need to list results for all substeps and I can only access results from the LAST substep. When I change substep, it says: "load set not found on results file file.rst". What do I need to do in order to view results for all substeps?
thanks and regards,
Hugo
RE: how to view results for all substeps in a nonlinear analysis on ANSYS mechanical
Before you solve issue outres,all,all. This will save all substeps on the results file. By default only the last substep is saved.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Thanks a lot. It works perfectly!!!
