How to give my model initial velocity in Adams/View?
The pics attached is my model of a twist beam rear axel with 2 wheels. I want to simulate it to run with fluctuated torque. But what I want to measure is the constant velocity phase of the simulation. But it absolutely will cost much time (my step size is 0.001s).
So, I was wondering how to give the whole model initial velocity to skip a lot of acceleration time.
Here is the topology of my model.
a revolute joint connect wheel and suspension;
a parallel_axes primitive joinnt connect chassis and ground;
1 bushing and spring connect suspension and chassis.
here are my questions:
1. I know there is a option in each joint to give initial velocity, but which joint should I give?
2. I don't know why. But I once tried to give initial velocity to the rev joint between wheel and suspension, the model still ran from static.
Can anybody answer my question???
thx!!
Tongji University of Shanghai,China
RE: How to give my model initial velocity in Adams/View?
For a trouble free run starting from a velocity you need to give an appropriate velocity to every part, so in the case of a wheel you'll need to give it both a translational and a rotational velocity. The initial velocities apply to parts not joints.
Cheers
Greg Locock
