How do I wrap text around a sketch curve using NX 7.5?
Referencing post: thread561-226111: Wrap text
Please see attachment. I am using NX 7.5 and want to wrap text around a curve on my detail drawing. This is for silk screening so I don't believe it is necessary nor do I want the text to show on the model. Does anyone have a solution?
eneumann
eneumann
RE: How do I wrap text around a sketch curve using NX 7.5?
Top pull-down menu change to On Curve
You will need a curve as a baseline for the text but you should be able to figure it out
Ask if you need more help
Your solution seems to be in modeling rather than drafting. Do you know of a solution in the drafting role?
If you don't see the below pull-down menu then you may want to check your Roles
Insert -> Curves/Points -> Text
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
