Plan 1 seal, flushless?
I've been having a hard time understanding terminology regarding mechanical seals. Difference between flush water and seal water?
I have a pump that will be processing seawater and am planning to go with a John Crane Type 1 seal. The question is whether or not we need external flush water (from the domesitic water supply) or if it can be a flushless seal.
My understanding of flushless is where you use the process fluid as the flush/seal water? Please correct me if I'm wrong or if there an online resource out there that may be able to help me out.
Thanks!
Thanks!
RE: Plan 1 seal, flushless?
Another newbie question. Since we are using a mechanical seal, there is no Packing Gland or Stuffing Box? Or does this stuff just come standard from the pump manufacturer?
Sorry for the rookie questions, trying to learn.
