how to make do while loop
I want to do steady static analysis on a pressure hose. I want to make a *dowhile loop regarding the pressure load. I mean loop should be like at the first step it applies pressureload=1 MPa and with the incerease in every cylce in keep on incerease line pressureload=2, pressureload=3, pressureload=4, .... till pressureload=10. And it will save separate results file with every cycle. So I can know about the true behaviour of material law.
If any body can make me a sample that would be very nice. If you any other method about this, please explain to me, because I am new to ansys and do not know much about apdl. Thanks
Kind Regards,
Adil
