Part list tamplate
Part list tamplate
Hi there,
I'm making a part list for a machine ,and I don't now what's the best format, and I have another question , is there any standard way to make a specification for a part like if I have a palte so in the specification column typing length*widht*height. any help please?
RE: Part list tamplate
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
What does your requisition form look like? You ought to be able to prepare requisitions by cutting and pasting from the parts list.
JHG
thread292-331379: What is the standard using to specify a machine part?
Assuming you're sticking with ASME for part naming I already mentioned Y14.100 in the other thread. For parts lists try Y14.34.
Neither probably have the level of detail you want though.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
