Difference between force and force per area of FEMAP
What exactly is the difference between a force and force per area on FEMAP?
RE: Difference between force and force per area of FEMAP
Tobalcane
"If you avoid failure, you also avoid success."
“Luck is where preparation meets opportunity”
"People get promoted when they provide value and when they build great relationships"
TTFN
In FEMAP there are 35 loads available for loads on surfaces. Many of the load types, such as force, force per area, and force at node are just different input methods for the same nodal load type (Force). These different input methods enable FEMAP to distribute loads along the surface.
There are three basic types of load input values: Total, Per Area, and Per Node. The total loads include force, moment, and heat flux. Input the total load value, and FEMAP will automatically distribute it over the surface. The distribution will be based upon the total area associated with each node. Total loads must be input as constant. They cannot be variable.
Loads input as "per area" loads (force per area, moment per area, and heat flux per area) are very similar to "total" loads. The load is distributed identically to a "total" load, except the values are then multiplied by the area associated with each node. The sum of all these loads is simply the input value multiplied by the total area of the elements. These types of loads must also be input as constant.
Please note that TOTAL FORCE option is only available for Force, Bearing Force, Moment, and Torque load types applied to surfaces. Allows you to enter the "Total" Force, Bearing Force, Moment, or Torque to be applied over all selected surfaces, not applied to each surface. Uses surface area to spread the load out proportionally. Total Load is the default for these load types when more than one surface has been selected. When used, "Total" will appear in the default Load Definition title.
Hope it helps!!.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
if you apply 50 lbs/unit area to a surface, FeMap will apply that pressure over the surface to determine the applied load.
no?
Only then should you start looking at other results (deflection, stress).
tg
