what is the acceptable criteria for a csa z662 closure weld
I am currently facing a situation where I will have to weld tested pipe into pipeline that has just been tested. all the piping has been tested. The pipeline falls under CSA guidelines. I can find a code reference for closure welds that refers me to ASME s.8 d.1 I will mag the hot pass and cap with hardness test. Is this acceptable under CSA guidelines.
RE: what is the acceptable criteria for a csa z662 closure weld
