Gas Turbines Output lost
What is the main reason to lose output since we pass to combined cycle?... backpressure? If someone has a good explanation, it would be great!
JC
RE: Gas Turbines Output lost
Hi JC
I would imagine back pressure is the most likely reason, though I would have thought the waste heat recovery designer would have minimised this as far as possible based on exhaust mass flow rates.
Also is it possible a damper is not functioning correctly?
Cheers
John
