Assign numbers to the faces in solid body- Grip File
Does anyone know how to write a grip file to assign numbers to a solid body in UG NX7?
Thank you,
bliou
Thank you,
bliou
RE: Assign numbers to the faces in solid body- Grip File
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Than you for replying. Basically, i am using attribute function to assign a title and string value of each face in a solid body. This process can take hours and i was wondering if this can be done by using a grip file so i can save some time.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
For example for a hole, the title will be " hole" and the vaule will be a number.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Regarding applying attributes to the faces I would suggest that surely the only reason for doing this is to use the attributes to be used for some downstream action. If that action can be done directly then the need for using attributes becomes redundant.
Frank Swinkels
Thank you for your response. Yes, your program will definitely fit my need. Please advise.
bliou
It is important to let me know your NX version. Also if you need it for both inch and mm parts. After I have the info I suggest that we start by using a color for a range of hole sizes. For example
0.0 > 1.0 mm color 1
1.0 > 2.0 mm color 2 etc
similarly for inch
If you have a diferent requirement or if you want to use specific colors please let me know.
Frank Swinkels
I am using UG NX7.5, inch parts and I agree that we start with your suggestion or we can start by assigning colors and numbers to all the faces within the part.
Thank you for your help.
Anyway this is a start. Let me know what you think.
Frank Swinkels
