True position of sphere
Is there a difference between the following feature control frames (FCF) to control the position of a sphere using the attached intentionally incomplete drawing to put it into context?
FCF A
|TP|SØ.1|A|B|
|TP|.05|B|
FCF B
|TP|Ø.1|A|B|
|TP|.05|B|
My instinct is that they are equivalent - the lower frame truncates the poles of the spherical tolerance zone in both.
FCF A
|TP|SØ.1|A|B|
|TP|.05|B|
FCF B
|TP|Ø.1|A|B|
|TP|.05|B|
RE: True position of sphere
FCF A
|TP|SØ.1|A|B|
|TP|.05|B|
FCF B
|TP|Ø.1|A|
|TP|.05|B|
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
I'm not sure I see your point. Re FCF B, doesn't the actual center of the sphere have to meet both conditions, i.e., lie within the a .1 diameter cylinder and within the planes separated by .05? In my head, I'm imagining a cylindrical tolerance zone that is .1 in diameter and .05 tall. Since the cylinder's axis is coaxial with datum axis A, doesn't that include in/out of page?
In FCF A, the resulting tolerance zone would be a sphere with its poles chopped off.
I drew the tolerance zones in the attachment. Let me know what I'm missing.
I'm not totally comfortable with either option. I'm just saying that they don't seem to be the same, and B is probably ambiguous.
John-Paul Belanger
Basically, In the second statement you expect A alone to esablish a zone it alone can not support as it is a circular zone in a veiw diretionally oriented in the plane of the paper since it is shown in that view. I suspect you think it is a zone controlling into the depth of the paper, like a spherical zone would automatically do.
I am not a fan of seperate incomplete frameworks unless now other way will gey the job done.
I have a lot of interest in this subject myself.
thread1103-314840: What Is The Correct Position Tolerance Zone Of A Sphere To A Plane
thread1103-322523: Sphere features to planes 2?
