cleaning magnesium
3
cleaning magnesium
cleaning magnesium
what are the no-no's for cleaning this metal???
We imeresed ia piece in out cleaning a
tank and it turned black,,,HELP.....
RE: cleaning magnesium
If your piece turned black, you probably got a smut from oxidation.  In general, you should not acid pickle, but rather you should use alkaline cleaning.  ASM Handbook Volume 5: Surface Engineering gives good information acceptable practices.  It is available at:
http://www.asminternational.org
ASTM has a number of good references with respect to magnesium surface preparation & corrosion:
ASTM D 1732 STANDARD PRACTICE FOR PREPARATION OF MAGNESIUN ALLOY SURFACES FOR PAINTING
ASTM B 879 STANDARD PRACTICE FOR APPLYING NON-ELECTROLYTIC CONVERSION COATINGS ON MAGNESIUM AND MAGNESIUM ALLOYS
ASTM B 480 STANDARD GUIDE FOR PREPARATION OF MAGNESIUM AND MAGNESIUM ALLOYS FOR ELECTROPLATING
B 480 references the standard guide ASTM B 322, which is an excellent reference for all metals
ASTM B322 CLEANING METALS PRIOR TO ELECTROPLATING
ASTM standards can be obtained from ASTM at http://www.astm.org or from Global Engineering Documents at http://global.ihs.com .
There is a military spec, MIL-M-3171 MAGNESIUM ALLOY, PROCESSES FOR PRETREATMENT AND PREVENTION OF CORROSION ON, that has some information on this subject as well.  It has been officially superceded by SAE-AMS-M-3171, but you can still download the last version of this document, free of charge, using ASSIST-Quick Search at http://assist2.daps.dla.mil/quicksearch/
