All-bolted single-angle connections
For all-bolted single-angle connections can you confirm that I have calculated the connection capacity correctly?
Per AISC Table 10-10.
For 2 (3/4") bolts (LRFD design):
phi*(Rn) = C * phi(rn)
phi*Rn = 1.03 * 15.9 kips
phi*Rn = 16.4 kips
Is the 16.4 kips the total connection capacity? Or do I multiple 16.4 kips x (2 bolts), so that 32.8 is my connection capacity?
Thanks.
phi*Rn = 16.4 kips
Thanks.
RE: All-bolted single-angle connections
In your case, the 16.4 K seems to control.
