Trying to simulate Bending Moment test on pipe coupling assebly
Thanks for your time!
I am trying to simulate a bending moment test on a pipe coupling assembly. I have attached a diagram of the moment test and also the assembly file. I am trying to model the test as accurately as possible, but encounter many errors when I think I am choosing the appropriate fixtures and can't get any realistic results. The pipes, sleeve, ram, and base are made of steel and the couplings HYLON N1013 (similar to nylon 6/10). The ram pictured in the model can be suppressed if needed. Any help would be greatly appreciated!
-William
bending moment test diagram: http://files.engineering.com/getfile.aspx?folder=7...
model screenshot: http://files.engineering.com/getfile.aspx?folder=a...
