Camber change and dynamic trail
I have a quick enquiry about drawing the front suspension of a vehicle
When considering the centreline of a wheel to calculate scrub radii and track width, is camber ignored as per the second picture? Or is the center of the actual contact patch the more important dimension? I understand that the shape and position of the contact patch is significant when considering dynamic trail and steering feedback.
I imagine that a picture is worth more than a thousand forum posts.
RE: Camber change and dynamic trail
Cheers
Greg Locock
Mx is an often ignored tire property that is quite important during large Ax and Ay maneuvers.
Cheers
Greg Locock
I hadn't realised it could be as much as 20mm.
Cheers
Greg Locock
