dP for turblance fluid at change of direction
Hi All,
This question might be silly, but it has annoyed me for quite a while,
Say for a fully turbulence fluid, all fluid particles are flowing in all different directions, therefore the fluid main stream may have a direction, but each individual particles all have their own moving direction. Once the fluid hit a elbow or a bend, why would there be a pressure drop? as each individual particles are all still moving in all directions, hence no change to fluid condition.
Could someone please advise?
Spoonful.
RE: dP for turblance fluid at change of direction
Energy was required to change their direction. You have the wrong concept of hydraulic pressure. Pressure drop is not force/unit_area in the case of hydraulics, it is a unit of energy that has been expended. The same energy needed to effect the change in direction of the fluid at a bend, or force it to move ahead in a straight pipe.
"People will work for you with blood and sweat and tears if they work for what they believe in......" - Simon Sinek
And the wrong concept of turbulence. Yes, the motion of the particles has a random velocity component, but that random component is (must be) much smaller than the mean flow velocity. I.e., it is extremely unlikely that particles in the flow ever have a velocity in the negative (against the stream) direction. Not counting gross eddies.
