How to read all the notes in my drawing using NXOpen in NX 7.5 ?
Hello Everyone ,
Can someone please let me know how can i read all the drawing notes in my drawing using NXOpen(i.e the Note Text , Origin etc) as i did not find any way to get the note collection in my drawings ?
A sample code snippet will be of good help.
Your help in this regard will be deeply appreciated.
Amitabh
Amitabh
RE: How to read all the notes in my drawing using NXOpen in NX 7.5 ?
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.Annotations Module report_all_notes_text Dim s As Session = Session.GetSession() Dim lw As ListingWindow = s.ListingWindow Dim dp As Part = s.Parts.Display Dim nc As NoteCollection = dp.Notes Sub Main() lw.Open() For Each a_note As Note In nc Dim the_text() As String = a_note.GetText() lw.WriteLine("Note has " & the_text.Length.ToString & " lines") Dim ii As Integer For ii = 0 To the_text.Length - 1 lw.WriteLine(the_text(ii)) Next lw.WriteLine("") Next End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer Return Session.LibraryUnloadOption.Immediately End Function End ModuleSuresh
www.technisites.com.au
