Is there a way to print some drawin
Is there a way to print some drawings one in the side of other in a plotter in SolidWorks?
RE: Is there a way to print some drawin
I think it depends on your Plotter.  At my last company, we had a HP DesignJet 800ps, and we were able to use the "paper save" features of the plotter to print more than one drawing on a sheet.  I don't think you can nest several SW drawings like you can in AutoCAD though...
"The attempt and not the deed confounds us."
There's a handy application out there that allows you to print to a PDF file. I would think you could then use Adobe to combine PDFs and stack-up your drawings and then print them as you like.
But you have to compare the cost of wasted paper to the cost of your time spent dinking around with this.
aka: Little Debbie's Boy-Toy
