Is it possible to average out synchronous vibration?
Dear all,
I am new to the vibration analysis field. I am curious to know, is it possible to average "out" synchronous vibration data by using an analyser?
I know that synchronous time averaging with the help of a tracking filter helps in eliminating noise. Is the reverse possible? Can I use a tracking filter (key phasor or reflective tape laser sensor) to remove the synchronous components from a signal? In a hypothetical scenario where the GMF and any other high frequency vibration i.e. BPFI & harmonics or vane pass frequencies lie close to one another, will removing the synchronous components from the signal be helpful in identifying/emphasizing the non-synchronous bearing fault frequencies?
RE: Is it possible to average out synchronous vibration?
In the old TEC software of the 1980s it was possible to create spectra that were the difference between 2 spectra. I used it mostly for bump or impact tests.
I have no idea if modern software packages offer that manipulation.
There may be more than one way to do what you want. A Google search will bring up a lot of methods, some usefull and sone not. One way is to demodulate a bandpass filtered signal centered between synchronous harmonics, such as described here:
www.vibrotek.com/articles/
You could also search for Emerson-CSI PeakVue as another related method.
Walt
I'll add to the snowball. Yes, it is possible, it is not however especially easy in the real world to totally get rid of a strong synchronous signal (if it was we wouldn't worry about ground loops and mains hum).
Cheers
Greg Locock
