contour drawing for plasmacutting
We want to make a 30mm thick steel part by plasma-cutting the contour, and then adding small holes etc. on a mill.
I'm having trouble finding a proper way to create both the drawings (drawing for "raw" part and detailed drawing for the mill) and somehow make them dependent on each other and on 1 part number.
Any hints?
Any hints?
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
RE: contour drawing for plasmacutting
Hope this helps
Cheers
Si.
Best regards
Simon NX7.5.4.4 MP8 - TC 8 www.jcb.com
What Licenses do I need?
Alternatively: when I add the part in an empty assembly and make an assembly cut in it, I can model it as if I was in the part itself.
Is there a way to do this without having to use the assembly cut? That way I could add a raw material version as a part inside the requested part and model it to the finished part in the main assembly.
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
Cheers
Si
Best regards
