Steady-State Heat Transfer Analysis with FEMAP 10.3.1 and NX Nastran 8.1 (Shell and solid elements)
Can anyone give me some tips with Steady-State Heat Transfer Analysis when you have both shell elements and solids in the model. They are connected properly and a static analysis can be performed without any problems.
Is there any special settings you need to change in order to run the analysis when having shell elements???
Thanx and best regards
/Srki
/Srki
RE: Steady-State Heat Transfer Analysis with FEMAP 10.3.1 and NX Nastran 8.1 (Shell and solid elements)
Is there any other approach? I cannot do it with just solids because I need to do some parts as shell elements in order to verify against Eurocode (pressurized parts)...
Thanx in advance
