ABB protection REM543
Hello! I have to program one relay REM543. With displeasure I saw that in the Application library of CAP505 didn't have any configuration template only empty configuration. In my experience with REF54x there are several factory configuration, but for REM relay nothing. It is not a big deal, but software wants some sequence when starting from the beginning. I know how to add tasks of the processor and working sheet, but i prefer if someone have some tested template to start changing on it instead to start from beginning. So if someone have some template configuration or modifyied but tested I will be very grateful!
RE: ABB protection REM543
and I will attach for you some AR file
Thanks for your support!
Sorry, Im not have 6+3 with RTD
please find attached
file _1 6+3 but without RTD
file _ 2 7+2 but with RTD
try use file attached application and modify it, if you will have problem, I will help you and build some template.
