HSS moment connections with torsion
Hi, I'm designing a chin-up bar made of circular and square HSS sections. I am at a loss as to how to design the connections.
Joint A : Two round HSS are welded together at their ends with one member at a 30deg angle.
Joint B : A round HSS branch (CHS 3) is welded to a round HSS chord (CHS 2). The applied loading causes torsion about the branch member (CHS 2). Also, the applied loading causes bending of the chord (CHS2).
Joint C : Same as in Joint B, but this time the branch (CHS 3) connects to a square chord (SHS). Would I be able to convert the CHS dimensions into equivalent SHS dimensions, as described by Dr. Packer in this link? http://www.hss-steeltubing.org/connections.html
These HSS connections do not appear to be discussed anywhere in the book "Hollow Structural Sections - Connections and Trusses - A Design Guide", 1997, by J.A. Packer and J.E. Henderson, so any advice would be greatly appreciated.
RE: HSS moment connections with torsion
Joint B: Provide a fillet weld all around.
Joint C: Use Yield Line Theory to determine adequacy of square HSS wall. If necessary, reinforce with plate or increase HSS thickness. Provide fillet weld all around CHS at SHS wall.
BA
Is this designed to be a chin up bar with only 1 arm coming out from the wall? It seems like that would put a lot of torque on the arm and probably bend/spring quite a bit when in use.
M.S. Structural Engineering
Licensed Structural Engineer and Licensed Professional Engineer (Illinois)
Factored shear resistance for various angles to the axis of the weld are given in the CISC Handbook of Steel Construction and I assume a similar table is provided in the AISC document.
BA
1+(tau/tauyield)^2
where tau is the maximum extant torsional stress and tauyield the shear strength stress of the wall of the SHS, if and when the SHS wall is not overly thin.
We have always open the possibility of making a FEM model with initial imperfections and material and geometrical nonlinearities that would reassure us of the adequacy of the decision taken.
Where does the amplification factor for normal stresses come from?
A full FEM model seems like overkill, with a second CH3 member acting as a back span, the system shouldn't have all that much torsion.
not that different than this sort of system, right?
http://www.ultimatebodypress.com/wall-mounted-pull...
It is always a good idea to “to simplify the drawing,” if that confuses the description and explanation of the problem. Witness the questions you got. You are asking for free advice here, and many people or more than willing to be helpful. But, they shouldn’t have to play 20 questions, and always remember they can’t see what you are imagining or looking at. Always read your work picture (description) and sketch, and ask yourself, will someone who knows nothing about what I’m trying to do, only draw one picture, one free body diagram (the correct one) from what I’ve told them? Maybe a center line, with the note “symmetrical about the centerline,” and some load and reaction directions and values would have cleared your picture up.
dhengr : I was mainly interested in how to check HSS connections with the type of loads that are present in the sketch because they are not discussed in the book by Dr. Packer. As I understand it, HSS structures can fail at the connections even if the welds and members have enough capacity. But I do realize that I caused confusion with an incomplete drawing and I should have at least indicated that the drawing is symmetric. A new drawing is attached.
TLHS : The layout of the chin up bar is the way we would like to have it made, with functional and aesthetic purposes in mind. The CHS 3 bars also serve as pull-up bars so we do not wish to have them far apart from each other.
Thanks everyone for your suggestions!
The square section on Section 2-2 is member SHS. CHS1, CHS2 and CHS3 are circular hollow sections.
A butt weld at Joint A would need a backing plate if the CHS walls are thin. Perhaps the elliptical stiffener plate at the miter joint could be used for this purpose.
A fillet weld could be used at Joint B if the wall of CHS3 is cut normal to the axis of the member at the curve where the ID of CHS3 meets the OD of CHS2.
BA
Every time we talk of interaction, we talk of a limit condition, sometimes as a curve, others as a surface, and a fit to the safe limit of the behavior. Tresca, von Mises are examples.
In the case I refer to, excessive deformation by whatever way we discover it will mean that a more complex field of stresses has developed (say, tension field stresses may be extant at that moment) and hence a fit to the limit that only considers St Venant shear, extant shear and elastic normal stresses may be inadequate; there may be some warping restrained by tension field, large deflection stresses in place etc. An experimental formula (or sets of formulas) covering the failure of the connection would cover for all the significant aspects within the contemplated ranges of dimensions.
However the stated formula when the deflections remains quite small (mainly out of moderate stresses and/or relatively thick walls in the members) should give a good start to get a safe design.
Attached, Mathcad 2000 Professional for the design of a circular fillet weld subject to moment, shear and torsion. Note that taking the shear stress in a plastified statement as done in the worksheet is conservative, since it checks the points where the interaction is worst, namely where the normal stresses are bigger. The interaction check is as per Pilkey's and the deformations in the ring fillet weld assumed small.
