Opinions on screw pumps?
I'm searching for a reliable pump for chemical pulp pumping in elevated consistency (10-15 %). What's your opinion on screw pumps? Can they handle thick stock better than centrifugal pump systems? Do they actually require less power? Reliability?
All opinions are welcomed!
RE: Opinions on screw pumps?
Unless you are pumping more than 100 mgd of the stuff, I would say they are a nightmare.  The higer solids will only add to the problems typical of this type of pump such as trough wear, screw shaft deflection and on and on....
Look for a good progressive cavity type pump system or a reciprocating type.  I used a company called Penn Valley Pumps on a fiberglass sludge system with solids in your range and it is still working to this day.
Good luck
Bob
In general, we don't use centrifugal pumps to pump high-viscosity fluid(>2500 SSU) or solid. Try internal gear pump or lobe pump(for solid).
If I was a pump vendor I would recommend the most expensive pump. Very low flow rate 5 m3/hr could be low for some applications, but can mean overkill in others.
Please be specific  !!!
Steven van Els
SAvanEls@cq-link.sr
