Braking Force Distribution
Hello All,
I have a 2 span bridge with Expansion Joints at the abutments and all the bearings are elastomeric. Currently i have distributed the moment caused due to the longitudinal braking force equally to the abutment and the pier, but in actuality, the abutment with pile connection stiffness would be greater than the pier column connection(but due to presence of elastomeric bearings used on abutments and pier shouldn't the forces be equally distributed), SO i am thinking the percentage of moment distributed would be respective of its element stiffness. I am not sure if i should use equally distributed forces or determine the stiffness and then distribute the forces?
RE: Braking Force Distribution
