Line - color vs display color
NX 7.5.5.4
While working on an existing drawing, I noticed that some of the lines for the revision block were a different color. I tried to use edit display to change the line color to match the other lines with no luck. When I use "info object" on the stubborn lines, it shows that the lines in question have a "display color" in addition to the "color".
Any ideas?...Thanks!!
RE: Line - color vs display color
Is it a sketch line? If so, you can change the display color to match the object color by going to Edit -> Style (choose line(s)) and turn on the Display Object Color option. Otherwise the line display color is controlled by your sketch preferences.
www.nxjournaling.com
Could the revision block be a table?
Cowski, thanks for the help!!!
Jerry1423, no but maybe it could be...Hmmm
Do a
Information -> Object -> select line
and see what comes up about it
