Meaning of the expression "positively attached"
What is the meaning of "positively attached", referring to a wheel assembled in a shaft?
Thanks for any help!
RE: Meaning of the expression "positively attached"
like lockwire, threaded, pinned, castle nut + pin, ...
So attach your wheel consistent with the other performance and maintenance requirements and when you get to design review state "I'm positive that this wheel is attached."
Good luck,
Latexman
1. Verbal communication is maybe 25% effective.
2. Written communication with drawings in an agreed upon format, properly rendered, may hit 90% effective.
3. Neither rule is 100% true but either rule is better than thinking the communication is 100%
P.S. I like the image of a wheel in a shaft.
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
1 drawing = one thousand words
positively attached = (assy) make sure it is not lose for dummies. lol
HTH
Mfgenggear
Otherwise, I would think lanyard for "positive attachment," but that wouldn't be appropriate for the described situation.
TTFN
In this sense, it basically means "resists a reasonable amount of force in any direction," which makes sense insofar as terminology is concerned. I'd imagine that, for your application, it just means that the wheel won't slide on the shaft once attached.
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." -Scott Adams
system etc.
