Rebar Anchorage orientation
Hi, does anyone know why the details for anchorage hook of rebars (beam rebars hooking at columns) are facing towards each other. that is the bottom rebar hook anchorage is going up, while the top bar rebar hook anchorage is going down.
Does the orientation of the rebar hook have anything to do with the degree of fixity of the beam?
I have always thought that they were detailed that way due to practicality on site only. because it is not possible (unless you drill a hole) to hook the beam bottom bars going down if column below it is already casted. While hooking the beam top bar oriented upwards will make the rebar protrude when at the beam is at the upper most level (because there is no more column above the beam).
Any thoughts?
Any thoughts?
RE: Rebar Anchorage orientation
Columns are typically constructed up to the bottom of the beams with their vertical bars extended beyond. The beam rebar cages are then dropped into the formwork and therefore any bottom bars with hooks cannot hook downward into the as-cast column.
I should refer you to the CRSI Placing Reinforcing Bars book for a better understanding of construction issues.
