Hi , I have DL a test journal "d
Hi ,
I have DL a test journal "define_part_attributes_with_blockstyler.vb" from GTAC programming examples .
I know it just examples , but I have 1 question to the attached example.
The program set´s two partattribute´s - COLOR and FINISH.
When I run the journal , it is 3 options to each Attribute ( red,green,blue for COLOR and nitrate,polish,mill for FINISH).
So long it work´s great.
But if I run the journal one more time ,and the attribute COLOR is already set(Ex "green", this value from the attribute is not present in the dialog.
The present value is always the first value defined in the stringArray.
When I read the program ,I understand why it work´s so..
But should it be possible to get the current value of an existing attribute (COLOR or FINISH), present in the dialog ( created from Block Styler)?
lko
lko
RE: Hi , I have DL a test journal "d
So instead of just displaying three values for COLOR & FINISH by reading existing attributes and if they exist then their values can be added as shown in the sample code
CODE -->
'assuming you have found the attribute values as string variables color1 and finish1 Dim stringArray(3) As String stringArray(0) = "Red" stringArray(1) = "Green" stringArray(2) = "Blue" stringArray(3) = color1 enum0.GetProperties().SetEnumMembers("Value", stringArray) stringArray(0) = "Nitrate" stringArray(1) = "Polish" stringArray(2) = "Mill" stringArray(3) = finish1 enum01.GetProperties().SetEnumMembers("Value", stringArray)If you need help in getting the attribute vaues you need to let me know what version of NX you are using.
Frank Swinkels
thank you for your quick answer , but I think I don´t have explained me very well (sorry).
I understand your solution - but what I want it to do is - if one of the 3 values is already set as a attribute,
next time I run the journal, the actually value should be "visible" in the dialog,so the user know what the current value is at current moment.
As it is now ,always "Red" is shown as the first choice. (and "Nitrate" ind the next field).
maybe a solution will be to set all values in the stringarray as variables ,and then the first varibale should be "triggered" to show either existing attribute value if it exixt, else
the first varibale must be set as "Red" , in the stringarray.....
lklo
Yes, for that we need to read the existing attribute. The way to read the attributes has changed in NX8, that is the reason Frank asked you what version of NX are you running. Depending the version we can post the code to read the attribute value.
Suresh
www.technisites.com.au
NX 8.0.3.4
lklo
enum0.GetProperties().SetEnum("Value", 2)
This means that the attribute for color was Blue. That is the third entry in the list. This means that the enum will show Blue.
Frank Swinkels
lklo
Thank´s a lot,
it work´s great with the "enum0.GetProperties().SetEnum("Value", 2)",but in my case,first I have to ask for each attribute , if they exist,(UF)
and if the attribute exist,ask for the value.Then calculate what number the value have in the array ,and then put that number (as variable - array_number -) in the
enum0.GetProperties().SetEnum("Value", array_number) ,<<< "2" replaced with the number variable.
I have written all attribute´s , array´s and array values (Enum) as variable , so it is very easy to set up for example 10 predefined part attributes containing 5 options each, in this journal.
The advantage with this solution is, if all attribute´s is set once , and the user have to change one of them, the remaining 9 attribute is preserved,and the user don´t have to set them again.
lklo
