Abaqus 6.12 starting error
Hey guys,
I use a shared computer at uni, with Windows 7. This morning I tried to start my Abaqus and got this message:
"This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Abaqus Error: Unable to shutdown executable for Abaqus/CAE. Exiting..."
And then comes another box saying:
"SMACgmCaeGuiMod has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is avaiable."
I searched in the forum for some similar thread, but couldn't find. Searching in other forums, I tried to add some commands in the abaqus_v6.env file, but kept on failing.
I have no idea what can be wrong. I tried uninstalling and reinstalling, fail. Do you guys have any idea of what can I do for fixing it?
RE: Abaqus 6.12 starting error
Try running abaqus with these startup options:
abaqus cae noenvstartup
abaqus cae noGui
abaqus cae noSavedGuiOptions
can you post the contents of these files:
abaqus_dir/SMA/site/abaqus.app
abaqus_dir/SMA/site/abaqus.aev
abaqus_dir being your abaqus install directory.
I can run the prompt, I don't know if that is abaqus viewer, but I cannot see the software interface. It reads the licenses and then brings that message I've posted before.
I tried all those commands on Abaqus Command and didn't succeed. "Abaqus/CAE Kernel exited with an error", "cae exited with an error" and "Command line option "noSavedGuiOptions" may not be used with "cae"", respectively.
So I tried "abaqus noSavedGuiOptions" and failed again ("Abaqus/Analysis exited with error(s)").
And here it is:
abaqus.app:
# Table of valid application names
# The first argument in the line is an application name;
# The second one is a relative path wrt ABA_PATH where
# the application is found. Exception is perl which
# is sought using PATH environment variable
# Any arguments following the first two will be passed
# to the application. Use -argument1 value
# -argument2 ... syntax.
PDE pde
abauserapp
adams
adb_dump adbT_test -adbdump
analysis
append
ascfil
cae
cfd
checker python/lib/driverChecker
compDDB compDDB
compressOdb compressOdb
compactMdb compactMdb
compLocId
compSIM compSIM
continue
convert
cosimulation
coverage python/lib/driverCoverage
cse
custom
datacheck
debug python/lib/driverDebug
decrypt python/lib/encrypt -decrypt
doc
dsm_dump dsm_dump
dymola dymolaDriver
emloads
encrypt
execsimulation
explicit_dmp explicit
explicit_dp_dmp explicit_dp
extractApi
extractOdbApi python/lib/extractApi -odb
fetch
findkeyword
free
fmi
volAddedTemp calculateVat
fromstl stl2aba
fromansys ans2aba
fromeni
fromnastran
frompamcrash
fromradioss
fromreservoir
fromdyna
help
hpv
information
killanalysis
ksyntax
libdep
licensing
make
mergeOdb
moldflow
movieplayer
networkDBConnector
odb_dump odb_dump
odbreport
odbcombine
optimization python/lib/optimizationProcess
odb2sim
parametercheck
paraview
pde
perl
pngdiffs pngdiffs
profile python/lib/driverProfile
python Python
qadump qadump
qualifyinterconnect
recover
relInfoGenerator
restartJoin restartJoin
resume python/lib/suspend -resume
romDump python/lib/rom_Dump
romDumpTree python/lib/rom_DumpTree
rom_Neuter
safe
schLicRpt
script
sendmail
sim_dump SMATlsDump
sim_version SMAAspConvert
sim_inspect SMATlsInspect
sim_neuter SMATlsTstNeuter
sim_report SMATlsReport
sim_diagnostics_dump di2T_DiagnosticsDumper
sim_neuter SMASrvTstNeuter
standard_dmp standard
substructureCombine substructureCombine
suspend
syntaxcheck
sysinfo
tb python/lib/hksTb
terminate python/lib/suspend -terminate
test
tonastran
tooutput2 odb2op2
toodb
tosid generateSID
tosim
tozaero toZaero
unittest python/lib/mpiUnitTest
unzip SMAExternal/unzip
upgrade
verity
verify
viewer
whereami
xcontpac python/lib/continuePac
xmaxdisp
zip SMAExternal/zip
stdtEigResRecovery python/lib/stdtEigResRecovery
kneeApp cae -custom kneeApp -nost"
abaqus.aev:
"ABA_PATH $ABA_HOME:$ABA_HOME/code:$ABA_HOME/code/bin:$ABA_HOME/CAEresources:$ABA_HOME/SMA:$ABA_HOME/code/bin/SMAExternal:$ABA_HOME/SMA/site
PYTHONPATH $ABA_HOME/code/python/lib:$ABA_HOME/code/bin:$ABA_HOME/tools/SMApy/lib:$ABA_HOME/tools/SMApy/lib/python2.6:$ABA_HOME/tools/SMApy/lib/site-packages:$ABA_HOME/tools/SMApy/lib/python2.6/site-packages:$ABA_HOME/tools/SMApy/lib/python2.6/lib-dynload:$ABA_HOME/tools/SMApy/DLLs:.:$PYTHONPATH
ABA_LIBRARY_PATH $ABA_HOME/ABA_SELECT:$ABA_HOME/code/bin/SMAExternal:$ABA_HOME/code/bin/SMAExternal/Interop:$ABA_HOME/code/bin/SMAExternal/Elysium:$ABA_HOME/code/bin:$ABA_HOME/tools/SMApy/lib/python2.6/lib-dynload
ABA_BLA_LIBRARY_PATH $ABA_LIBRARY_PATH
_NT_SYMBOL_PATH $ABA_LIBRARY_PATH
ABA_ATOM_DEP_LIB_PATH $ABA_LIBRARY_PATH
ABA_MPI_LIBRARY_PATH $ABA_LIBRARY_PATH
SMASVT_ROOT_PATH $ABA_PATH:$PATH"
Any idea of what's going on?
Cheers!
So either I'm wrong or they added the mod in one of the default folders.
Maybe you can do a system wide search for SMACgmCaeGuiMod, including the text inside files.
Else I have no idea.
"BSFBuildtimeData
SMAAbuAbaqusUtilities
SMABase
SMACinCaeInter
SMADmp
SMAFoxAPI
SMAInbInteractiveInfra
SMAIngInteractiveInfraGUI
SMAPybindings
SMAPython
SMAVagAtvGui
CATIADataBasics
LCCommon
SMAAspAnalysisSupport
SMABla
SMACcoCaeCom
SMAControl
SMAElkElementKernel
SMAFeaBackbone
SMAFeoFeaSimServices
SMAFlexnet
SMAFsm
SMAI2sInp2Sim
SMAIof
SMALamLibAdvancedMath
SMALgrLibGraphics
SMAMsgCommServices
SMAMsgFeaMessaging
SMAMtx
SMAObjSimObjects
SMAOdb
SMAPltModelerCore
SMAPyaModules
SMARaster
SMARom
SMARts
SMASglSimGenericLayer
SMAShpShape
SMASim
SMASrvSimServices
SMAUzlUtiZlib
SMAVcoVwrCom
SpecialAPI
SysSSL
System
SystemTS
VENFORTRAN"
Can you see something wrong?
Cheers!
The first one is on abaqus_dir\Abaqus\6.12-1\code\productIC, which I posted the content;
There are also two shortcuts (one in the Administrator\Recent path) and another one in Users\Administrator\AppData\Roaming\Microsoft\Windows\Recent Items;
And a last one with no path, no type specified just a internet explorer icon with that name, and if I try to open, it says that windows could not find...
Any idea?
Cheers!
Hi there,
I think it might have something to do with drivers or windows updates. I've formatted my laptop (sony vaio VPC series) and installed Abaqus 6.12 and Abaqus was running fine. After a few system updates, it stopped working...
Did you manage to solve this issue recently?
what is env file?
I've solved it before formatting my computer. However, now I've had the same problem in another computer.
If I toggle "RUN AS ADMINISTRATOR", it works perfectly.
Hope it helps.
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
/abaqus-612-graphics-devices/
