How to add different sketches in drawing to groups using NX Open in NX 7.5 ?
Hello Everyone ,
Can someone help me out with a sample code of adding sketches , notes to a given group in drawing.
Also while i was trying the same manually , i found out that the sketch appears in the part navigator instead of the active group and if i add the sketch later after creation to the group it is duplicated at both the part navigator and the group. I simply do not want any sketches reflected in the part navigator tree.
Note : I do not want to use sketch group in NX as sketch group only supports Sketches.
Please help , as i am stuck !!!
Thanks and Regards,
Amitabh
Thanks and Regards,
Amitabh
RE: How to add different sketches in drawing to groups using NX Open in NX 7.5 ?
Please find attached a snapshot showing the sketch which is appearing in the part navigator when i try to add lines , arcs etc (as shown highlighted in the image file).
I just wish to add the sketch lines drawing etc to the group directly.
Please revert in case of any clarifications.
Amitabh
Suresh
www.technisites.com.au
Can you please let me know how do i set filters?
Amitabh
Right click inside Part Navigator -> Filters. In Filters dialog pick sketch in the drop down menu and click the '-' (minus) sign.
Attached is the image.
Suresh
Please refer to my attached image in which the part navigator is not showing any sketches without using any flters.Also the lines directly appear in the group.
I wish to replicate the same behaviour using code.
Amitabh
