expansion of a clamped bushing
Hello everybody,
when an aluminium ring (OD 100mm, ID 90mm) is heated up from lets say room temp to 200°C it increases its diameters. But, what happens if this very aluminium ring is pressed into an other ring which has a much lower thermal expansion coefficient? Will the ID of the aluminium ring by itself and pressed into another part be the same at the same temp?
Easy question but can not figure out the answer.
regards,
Catho
regards,
Catho
RE: expansion of a clamped bushing
