Patterns vs New Title Blocks
I'm testing to replace the Patterns to the 'more intelligent Drawing boarders and
titleblocks'.
I have some questions :
1) All drawings that use pattern as titleblock, if I change the original pattern, all drawings at opening have the new modified pattern.
If I use the new titleblock, if I change something in the orginal titleblock, the change will be present only on the new drawings.
Solutions ?
2) To create the titleblock I used a dummy file component.
This file, if it remains in the drawing template perit to me create a correct template, but if I delete this dummy file before to use the command 'Mark as template', the template doesn't work.
3) Why SIEMENS template doesn't have dummy file in the template ?
Thank you...
Using NX 8 and TC9.1
