SPACEGASS Software input
Hello, I have created a structure on spacegass and entered member sizes in as mm instead of m as default requires. I have spent many hours and would like to avoid starting again if possible. Does anybody know a shortcut to convert member sizes from mm back to m other than editing details and dividing values by 1000 in the data-sheet manually?
RE: SPACEGASS Software input
Use the scale nodes function
Copy the nodes sheet to Excel, divide by 1000, then copy back into spacegass.
