looking for manufacturers of large scale composite pressure vessels
I’m looking for manufacturers capable to produce large scale composite pressure vessels. Preliminary specifications to have an idea of what I’m looking for:
Operative pressure: 200bar
Dimensions: 2.5m diameter, 20m length
Configuration: internal liner required (e.g. metallic AISI 316L)
Operative temperature: -40°C – 65°C
Could anyone can suggest me possible providers of this kind of components.
Thank you very much in advance.
R
RE: looking for manufacturers of large scale composite pressure vessels
Look up ATK, Clearfield, UT, USA
ASC Process Systems... www.aschome.com
OEM manufacturers recognized and approved manufacturer
hope this helps
are you sure about the temp range?
sorry got it wrong...ATk is a good option or basically every company having that large autoclave....
Aerojet in Sacramento does filament wound pressure vessels.
